RCU Forums - View Single Post - BIG PROBLEM!!!
Old 10-10-2007 | 08:28 AM
mclina's Avatar
mclina
Default RE: BIG PROBLEM!!!
ORIGINAL: acarter
ORIGINAL: spiral_72
ORIGINAL: acarter
ORIGINAL: Hossfly
would be to saw the glued joint apart. Using the belt sander,
don't you mean band saw and if so, unless you have a super huge band saw, the wing won't fit, meaning it will hit the throat of the saw, i think if your going to saw it the best tool to use would be a scroll saw, the blade is smaller and it doesn't matter how long the wing is
I'm pretty sure he meant belt sander. You can get them on a stand similar to a bench grinder, or you can get the handheld power belt sanders.
how do you saw the wing in half with a sander
There was a period between those sentences in Hossfly's post. "Saw the wing in half." and "Using the belt sander, I would..."
I misread it the first time myself...
