jetronics valves
Hi
I starting to be really desperate about the jetronics valves. I am pulling about 8 bar or 100psi to the air system with the gear train down. When I push the gear up button the valve lets the air escape thru the air out put and the train sticks in mid position.
If I start with gear up and then put gear down I have no problems. It seems like the electrovalve is not powerfull enough tomove from one position to the other.
Any imputs welcomed
Nuno
