RCU Forums - View Single Post - jetronics valves
Old 10-10-2007 | 12:44 PM
digitech
My Feedback: (10)
Default RE: jetronics valves
ORIGINAL: jetnuno
Hi
I starting to be really desperate about the jetronics valves. I am pulling about 8 bar or 100psi to the air system with the gear train down. When I push the gear up button the valve lets the air escape thru the air out put and the train sticks in mid position.
If I start with gear up and then put gear down I have no problems. It seems like the electrovalve is not powerfull enough tomove from one position to the other.
Any imputs welcomed
Nuno
maybe your cylinder is leaking over the oring?
cant imagine the valve to be bad
we operate them over 10 bars with no problems
