RCU Forums - View Single Post - Tamjets Gear failsafe Tip update for Spektrum radio
Old 10-10-2007 | 01:15 PM
BlackCloud's Avatar
BlackCloud
My Feedback: (12)
Default RE: Tamjets Gear failsafe Tip info update
Yep still working with the problem, even without the Tamjet unit connected if the gear position is selected up when bound, I have found that if you turn on the RX before the TX the gear retracts....not good on the ground. Works fine if the TX is on first though. But this way I know I am just bound to accidentally turn on the RX first. I haven't tried it with the gear failsafe intalled yet, its already too complicated.............your idea of a delay is good......if it could only know to delay until I remember to turn on the TX as well
BC
