RCU Forums - View Single Post - Suhloi with LS-50 engine.
Old 10-10-2007 | 07:42 PM
soarrich's Avatar
soarrich
My Feedback: (98)
Default RE: Suhloi with LS-50 engine.
I'm new to this, so does anyone see anything wrong with my can setup?
I had to cut about 1 1/2 inch off the header pipe to get the can in the tunnel. I could take a little off the can's intake pipe to move the can forward more, right now the back of the can is touching the curved end of the tunnel some.
I wrapped the can with teflon where the hose claps run around it. The hose claps are pop riveted to the bottom of the tunnel, and backed up on the inside with a thin sheet of aluminum.
ID:	780619   Click image for larger version
ID:	780620   Click image for larger version
ID:	780621   Click image for larger version
