Here is the same area several minutes later without the cabinet (1st pic).... Then working on down the side the sink was next... pretty easy, just unscrew some wingnuts to pull the sink and disconnect some flexible tubing. A few hundred screws and a bit of hammering later and that's done. Next is the worst so far... the heater/water heater. Yikes!!! Cut this connection, disconnect that etc... etc... etc.. and then take the outside vent off and pull it out that way... Then take all the screws around the outside off.... and find that two of the screws are rusted [:@] so time for the grinder!!! That got it to move, but wait, you can't with that gray cardboard (heavy duty) shield around it so tear part of that off too [>:]!!! That did it... watch out for the water draining out the bottom all over your shoes
Now there's a big hole but at least the big monster is gone... next the fridge.
