The fridge comes out pretty easy just some electrical and hoses. DON'T do it like I did and pull apart all the cabinets to get at it... [&:]there's another of those outside vents that will get you easy access to the back. Once the connects are off and you unscrew a dozen more screws around the front it slides right out and it's pretty light too! That water tank you can see beyond is easy as well. Just unscrew the outside fill and drains and pull off the hoses and it slides right out! That one I got right in one!!
