RCU Forums - View Single Post - BIG PROBLEM!!!
Old 10-10-2007 | 10:47 PM
tIANci's Avatar
tIANci
Default RE: BIG PROBLEM!!!
Shall we start a little fund to help out? Hehehehe ... You better have a thin blade and a high speed band/jig saw ... its balsa and it may shatter of you do not have a good set. Also, pray hard that the misalignment is just slight, if the spar was not tight and it would have set along with the glue then you have major problems. The spar has to go too.
