ORIGINAL: spitfire66
Just part of the game.
Yes
Make sure your cleaner has no ammonia as this will mess up the glue on the monokote causing bubbles.
Uh... No
Not much you can do. As you've seen, a deverter can help, but it's not 100%
4-strokes and gassers are a LOT less messy.
Also the design of the plane can make a difference, One plane may not collect as much as another.
Bottom line, if you don't like to clean oil off your plane, you'll need to go electric or switch hobbies
