RCU Forums - View Single Post - New Powerbox Royal twin Rx system
Old 10-11-2007 | 12:06 PM
Tom Antlfinger's Avatar
Tom Antlfinger
My Feedback: (24)
Default RE: New Powerbox Royal twin Rx system
1-Throttle
2-Ailerons (Y-connected)
3-Elevators (Y-connected)
4-Rudder/Nose Gear (Electrodynamics EDR-125 external mixer box) or could use Y-connector
5-Flaps (Matchbox)
6-Gear (EDR-125 gear failsafe so you can't put gear up accidentally on turn-on)
7-Brakes (Right Slider)
8-RX switchover detection channel
9-Smoker
10-Not used
This setup would work with Duralite Box as well.....you could actually get down to 7 channels if you don't use smoke and use the EDR-125 to do a down-elevator/brake mix....that way you get rid of brakes on channel 7 in the above example....but I don't like putting anything like a matchbox or EDR-125 between the elevators and the RX....
Tom
