RCU Forums - View Single Post - ZDZ 40 RE F3A Soft Mount
Old 10-11-2007 | 08:51 PM
MTK
Default RE: ZDZ 40 RE F3A Soft Mount
ORIGINAL: MTK
ORIGINAL: Magne
It will be interesting how much noise the intake will generate since it is practically inside the doughnut
Will you still have access to the needles?
Magne
When the engine is mounted in the plane, it will be inverted which means the needles will point up. I will need to locate them and drill access holes on the top side of the nose of the plane. I don't think that it's a big deal. A pair of rubber grommets will dress the holes up nicely
MattK
ID:	781282   Click image for larger version
ID:	781283   Click image for larger version
ID:	781284   Click image for larger version
ID:	781285   Click image for larger version
