RCU Forums - View Single Post - Some questions on lines
Old 10-11-2007 | 11:50 PM
EF
Default RE: Some questions on lines
Thank you Lou, I definitely will keep the elevator control conventional, only intend to control the throttle electronically.
It is obvious to me that the wire core of an insulated line is what is referred to and I see I probably did not phrase my question well however, what I was referring to was that given the wire core, and considering that the insulation adds weight and drag to the lines, should I shorten the length of an insulated line vs. the non-insulated same line I would otherwise be using, or does the insulation have a negligible effect?
