RCU Forums - View Single Post - Will this engine set-up cause problems?
Old 10-12-2007 | 09:26 AM
foosball_movie's Avatar
foosball_movie
Default RE: Will this engine set-up cause problems?
the angal of the needle valve should not be to hard to adjust. c-crunch
Why would I need to change the angle of the needle valve? It should still start and run the way it is currently set-up, correct?
