RE: JLT-750 Turbine ??
JLT750 Turbine Jet Set + Regal ECU + Monitor + 7.2V Battery, Pressure Tanl + Flightworks Fuel Pump + Accessories
Product Code : [JLT750SET]
Set includes:
-Turbine Engine
-Regal ECU
-Monitor
-7.2V Sanyo Ni-CD Battery
-Pressure Tank
-Flightworks High Quality Gas Turbine Fuel Pump 100A (FW-100A )
-Accessories
Specification:
Length (from top inlet to tail cone end) 156mm
Diameter:90mm
Weight: 850grams
Thrust idle: 0.40kg
Nominal EGT: 630Deg C
Maximum RPM: 160000
Fuel: Jet-A, Kerosene
Lubricant: Turbine oil.
Max Thrust: 14 lbs
List Price S$ 2,200.00
