RE: PPG Concept
Went ahead and ordered the Minijet IV with the 1.2 SR Tip. Will start looking at compressors now. I want to keep it small as to minimise its impact on my minimal garage space. Been looking at some of the DeWalt Compressors but am unsure of "Oil" or "Oil-less". I have read the oil lubricated are quieter and last longer. I am going to filter the supply line so I don't think it will matter what type.
Thanks for your many replies,
Phil
Looking at this one, any thoughts?
Heavy-Duty 200 PSI 15 Gallon 120 Volt Electric Wheeled Portable Workshop Compressor - D55168
Features:
200 PSI max pressure allows for longer air tool run time
5.4 SCFM @ 90 PSI allows for quick compressor recovery time
78 dBA (tested per ISO3744) operational noise level for a quieter work environment
Efficient high pressure technology allows for longer pump and motor life
Oil free, maintenance free pump, for convenient use
Efficient high pressure motor allows the compressor to be run with an extension cord (12 Ga. or heavier, 50 ft. or less) due to consistent amp draw requirements of the compressor
Compact design allows for the compressor to be easily moved, transported, and stored
Robust dual purpose handle provides additional protection to the compressor along with serving as a hose wrap
Metal console panel provides a display area as well as protects the gauges, coupler, and regulator
High flow air regulator allows for maximum air tool run time
High flow coupler allows for maximum air tool run time
2 inch gauges allow for an easy to read surface
Wide track, semi-pneumatic tires allow for additional stability, easy movement, and no tire maintenance
Ball drain valve allows for quick and thorough tank draining
