RE: whats the difference
da Rock's got it. The 30 minute is more penetrating into wood and other porus materials. It "wets out" better. It also has longer to link before it kicks and you get a more consistant result. Epoxy worls because the molecules form long chains. The longer it is "free" the longer the chains and the stronger the bond. I don't use anything faster than 30 minutes. Some of the West System epoxy I use is "120 minute". At that rate the amine waxes have a chance to float to the surface and you get a glassy result when hard.
