RCU Forums - View Single Post - Tower .75 Muffler
Old 10-12-2007 | 08:08 PM
opjose's Avatar
opjose
Default RE: Tower .75 Muffler
ORIGINAL: Geardaddys
After that I was determined to stop this problem dead in its tracks.. First I took the entire thing apart and cleaned it well with mineral spirits. Then I put the whole thing back together and used the red high temp RTV Silicone for making gaskets with.. great stuff.. Then I drilled some very small holes in the muffler where the can meets the front and the back housing and put some small screws into these holes to. Lastly, I threw out the through bolt that comes with the muffler and put a piece of threaded rod from the hardware store through the whole assembly and double nutted both ends of the threaded rod.. oh yeah, also used red locktite on the two double nuts... That bad boy hasn't even considered rotating on me or vibrating loose..
http://www.rcuniverse.com/forum/m_54...tm.htm#5706658
Pics above of what I did..
Great idea... I'm already drilling!
