The 28 gallon Campbell Hausfeld one I have is rated for 120 volt which is another reason I got it. I agree with Chris, dont get the 200 psi one....you will NEVER need that pressure capacity. For spraying you only use at the most 30 psi or so at the regulator and at the spray gun tip it is usually around 10 psi or so. 15 gallons will not last very long at all and the pump will be running CONSTANTLY. Being a diaphram type pump it will drive you nuts like mine does. Its loud and I usually wear headphones. Go with a larger capacity tank and around 150 psi rating. But again, just my thoughts.
Les
I just re-read your post and noticed that you said it is rated at 78 db... I have no idea what mine is at but I cant even hear myself think sometimes! [:'(]
Check this compressor at Home Depot:
http://www.homedepot.com/webapp/wcs/...ctId=100063473
