RCU Forums - View Single Post - Engine RPMs
Thread: Engine RPMs
Old 10-13-2007 | 03:58 AM
pe reivers
Default RE: Engine RPMs
That your idle needle is slightly lean. Starting will improve with richer settings, and idle rpm can be lowered to at least 1500. The downside is that the midrange becomes richer as well and will run not as smooth, though engine acceleration will improve over the whole rpm range. Final adjustment depends on how you fly, and what you need to be happy.
