RE: dx7 binding
They are not going to move. Fail safe leaves the surfaces the way the are and just drops to Idle. The surfaces lock in the last position if you are in a slight bank,, you stay there..
LATER
If you throttle is not going to idle you need to make sure you have the throtle set right and put it on Idle and rebind
