ORIGINAL: presso
I have been trying to bind my dx7 with a failsafe setup for low throttle,slight up elevator.slight r/h rudder,but the only thing that activates when i turn the tx off is the low throttle setting the rudder and elevator servos dont move.What am i doing wrong.
You can only achieve this if you are using a AR9000 or JR R921 receiver. As powerlines said, for all the other types of Spectrum receivers you will only be able to programme the fail safe position of your throttle reciver and the all other surfaces will hold their last know position.
Cheers
Pupmeister
