RE: Bobcat + Spectrum AR 9000
I have about 150 spectrum flights between two jets. My observation is that the numbers for your remotes is pretty normal while your receiver numbers are a touch high. Nothing much to worry about. The Rx fades represent a total of maybe 2 to 2.5 secs of data loss on those rx's over the whole time the system is on while the remotes are around a second or so. The 100 frame losses on the first flight is definitely high but still only a total of 2.5 secs. Sometimes you can get high numbers if you get the airplane way out on the ground. Did you check the ECU for failsafe activity??
I wouldn't change anything particularly but if you want, you can see if some slight repositioning of the receiver makes a difference
