RE: K&B 7.5 OB main bearing seized
What bearing are you trying to remove? It is one one on the PTO or crankshaft? Neither of these will come off with heat. The top case bearing and one left in the PTO after the shaft removal will use heat.. Just trying to understand which bearing you are trying to remove.. Sounds odd that 20 mins @ 350 won't let the bearing slip out..
