RCU Forums - View Single Post - nitro engine run too cool??
Old 10-13-2007 | 08:45 PM
twomanytoys
Default RE: nitro engine run too cool??
Yes it can hurt to run too cool. You need to check temps to make sure you are up to running temps. If you can pick it up by the head and it not burn then yes its too cool. Lean it out and either do a water drop test or use a temp gun. If it runs too cool you risk breaking a connecting rod. Should be between 220 and 260 for best performance.
