ORIGINAL: brewski
Be ready to replace the front bearing. Several have leaked. Mine is off to tower no for repair. I also have a new aftermarket set on the way that I will install if the new one leaks again.
....no so. If you go all the way back to when the T.H. 75's came out, until now....
....you would be hard pressed to find another front bearing leak failure.
FBD.
