First impressions of Sledge
"If you do not have a detailed section within the manual on the pull pull set up, then you are missing a section and should not proceed until Morris sends it to you. The instruction manual is very detailed and I think you will find there are few if any holes in it."
I looked through it all again and there is nothing on setting up the Pull-pull. Where in the manuel SHOULD be it be?
I started building tonight and got one wing half framed up. Tomorrow I'll do the other half and get them all finished...I don't understand what makes the center joint strong enough, but I'll just have to wait and see!
I went to the hobby store and replaced most of the 1/4 inch and a couple other sticks with some lighter ones. I want this thing LIGHT!
So far I really like how it goes together. It is definitely different than what I am used to, but I like it... Your instructions are great!
I can't wait to get this thing in the air...
