RE: BIG HORNET MAIDEN FLIGHT
Likai:
All Rhino's are produced to reach 36lb of thrust at our testing level of 6000' ASL. Some reach this thrust at less than our Maximum RPM setting of 118,000. Lewis' Rhino tested at 6000' ASL put out just over 37lb of thrust at 118000 measured RPM so at sea level, given the same or close to the same temp and humidity, is putting out slightly more.
Not to worry about twin operation. We can and will assist you with setting up two turbines to run "matched" for your twin when you are ready. When you are ready for the second Rhino, send me your current Rhino serial number. We will set parameters to these specification. You can also send us your Rhino, ECU and fuel pump and we will at -0- charge, set up two to be run together. Your only cost will be shipping. Please allow 10 days for return to you. This will insure a perfectly matched pair.
Best regards,
Eric Clapp
Jet Central Micro Turbines
Lifetime Warranty
