RCU Forums - View Single Post - Behotec JB66 - Why not?
Old 10-14-2007 | 12:27 PM
JimBrown's Avatar
JimBrown
Default RE: Behotec JB66 - Why not?
ORIGINAL: TED ANTON
I do not personally own a Behotec engine ( not yet anyway ) but I fly with a couple of guys who do run them and I can not remember a single issue ( besides a bad plug ) the engines run great.
I'm the guy that had a bad plug. Absolutly nothing to do with the engine itself. The element broke where it is welded to the plug side body, but maintained contact allowing the engine to start and no "bad plug" indication. However, after startup, the element vibrated, metal on metal, resulting in massive RF interference (keep in mind that no matter how well balanced, these engines still vibrate. At 35,000 rpm, even the tiniest vibration in that situation is not good.) Fortunatly, I caught the problem on the ground.
Having said that, and with the knowledge that some may see some bias in my comments (see sig.) I put just over 16 hours of run time over about 65 flights this past summer on my AD Phoenix with the Behotec J66HP. That bad plug was the only problem I had that was not the result of something I did (like forgetting to open the fuel valve.) I will be returning the engine to Peter this winter for inspection and installation of the kero start option.
Although the manual recommends a propane/butane mix for start up, I have had absolutely no problems using just propane (the green Coleman stuff.) I do not use an onboard propane tank.
Regards,
...jim
ID:	782771   Click image for larger version
ID:	782772   Click image for larger version
ID:	782773   Click image for larger version
