RCU Forums - View Single Post - 60 size Super Aeromaster Biplane
Old 04-01-2003 | 02:54 AM
blvdbuzzard
Default 60 size Super Aeromaster Biplane
Once you get the amount of rudder you need for take off you are set. The landings are easy. I just left it at a high idle until I was over the end of the runway and it would slow down. As it started to loose altitude I would give more and more elevator until it touched down.. The landing speed is so slow the roll out is just a foot or two. The way this plane flys is just awesome. It does not have a hi flight speed as you said but it does go up at the same speed.
Glad you had a good first flight day. You did land with the wheels first.
Dru.
