RCU Forums - View Single Post - Stab and elevator size... need help!
Old 10-14-2007 | 05:17 PM
BMatthews's Avatar
BMatthews
Default RE: Stab and elevator size... need help!
Generally airfoils with zero or low values of camber or airfoils that have lower pitching moment values will make do with a smaller tail. But the downside of a small tail is that the CG ends up being further forward. All else being equal the wing has to work less hard (think while in a pylon turn) if the tail is a little larger and will support a more rearward CG location while still keeping the model stable.
Shooting for a 30% CG location while still retaining a small % of positive stability is likely not a bad location. Size the stabilizer area such that when you run the numbers you end up with a CG located at that point.
