RCU Forums - View Single Post - Starting a Magneto Engine Without Using Spring Starter
Old 10-14-2007 | 07:55 PM
ram3500-RCU's Avatar
ram3500-RCU
My Feedback: (221)
Default RE: Starting a Magneto Engine Without Using Spring Starter
Years ago, all I had was mag type gassers. I had mostly Sacks but also had Huskies and Zenoahs. My procedure was much the same as with the Electronic engines I have now. Always started them by hand (except my hard starting Tarus[>:]) After all preflight and radio checks, and the plane tied down or held:
Choke on
switch on
full throttle
glove on
smack through compression till it fires and chokes out (usually 3-5 turns)
choke off
throttle to idle
smack through compression till it fires again and idles. (usually 3 or 4 turns)
Most of these engines like to be fairly wet to start.
