RCU Forums - View Single Post - Nitro Evader ST starting problems.
Old 10-14-2007 | 08:30 PM
N49185
Default Nitro Evader ST starting problems.
Alright, I bought my evader used a couple weeks ago. Ran it probbaly through one court of fuel. The day i buy the second court of fuel and running the first tank, it stopped. Let it cool for 5min..., went back to finish off the tank..., and the pull start was stuck in. Took the pull start apart, nothing that i saw that looked to lock it up. Took off the engine cover plate, and wow..., there where debris of the broken pistion shaft in the crank case. I ordered a new piston shaft, got that all squared away, then try to start it again...., wont start. Thought it was the glow plug..., got a new one, still did not start. Dissasembled the pull start and cover plate again, turned the carb to about 2 1/2 out on the high speed needle, opened the throttle and attempted to blow fuel into it. Nothing went in; then i had turned it to about 4/12 turns, fuel came out but not much.... I re-assembled the motor and attempted to start with 4/12 turns out, still did not start... After that point started to pull the heck out of it hopeing it would start. Nope..., checked to see maby if the engine was flooded, nope... After that point i still have no clue whats wrong with it..., And yes my glow starter had fresh batteries :P. Suggestions would be appreciated very much!
