DA50R Shaking Bad!!!
PUT THEM WINGS ON IT.........
Being that you are new to gassers, a "little" rich is better than a "little" lean. Gassers should be run VERY NEAR PEAK, but pay CLOSE attention to it. Check the spark plug FREQUENTLY. Pull it out and look at the end of it. If it is BLACK, then you are too rich. If it is WHITE, you are too lean. A well set up gasser will be TAN on the electrode.
