RCU Forums - View Single Post - DA50R Shaking Bad!!!
Old 03-27-2003 | 02:59 AM
Forgues Research's Avatar
Forgues Research
My Feedback: (7)
Default Re: In the plane and fly it...
Originally posted by flyin_hot
Hi Dennis,
In the plane and fly it is right. That comes directly from DA. There is a reason for that. You want to break the engine in as it would be flown in the air. The only thing running one on a bench will do is statically load it and heat it up. Never run a GS model without the wings on...some models will exibit 3rd order harmonics, and you may one day find you are holding up a couple of sticks...what used to be a model. Everything is bigger on a GS model...the size, forces, power, flight qualities, and other things ad infinitum. When you test a GS model, test it ready for flight...even if you are range checking it, testing controls, or anything else.
...flyin a little higher altitude at present, but still...
flyin_low
I think you missed what I said, on the bench to do first setup and then on the airplane.
