DA50R Shaking Bad!!!
if your moter was droped maybe the crankshaft is slightly bent.with all starting devices off and spark plug wires off,hold a scewdriver at top of cylinder turn prop till blade hits closest point without moving driver rotate prop to oposit side if the prop doesnt hit it the same may have a bent crankshaft
