RCU Forums - View Single Post - optic 6 / 450se
Old 10-15-2007 | 12:29 AM
heliaction's Avatar
heliaction
Default RE: optic 6 / 450se
Ok so assuming you have a mode 2 tx (left stick throttle), with the motor unplugged if you push up on the left stick the swash plate moves down and if you move cyclic (right stick) then you get for, aft, left, right movement correct? sowhat your saying is when you connect the motor, the rpm of the motor is dictated by cyclic??
