RE: 3w DA Help
Mine leaked too, and the answer, unless it's warped, is to take it off and use that loctite anaerobic gasket maker, just like Ron said. Make sure that when you put it back together, you don't overtighten the bolts. Mine have worked great since I've done this, and it's a lot less expensive that a new carb block.
Sam
