RCU Forums - View Single Post - CMP Zero Makeover
Old 10-15-2007 | 10:53 AM
ForkedTailDevil
My Feedback: (21)
Default RE: CMP Zero Makeover
Dollplayer...yeah i do not see why a G62 wouldn't work...the plane weighs about 20lbs with the US 41cc. The G-62 wouldn't def. be a large powerplant, just keep in mind you DO have throttle control. The 41 flys the plane scale....its not mach10fast but yet still has umph. I had to add about a pound and half up front..so a G-62 would suppliment the need for nose weight. The gear area i will admit SUCKS. Not strong whatsoever...if you look at my previous pictures the gear did end up rippin out on the second flight(mostly due to it being EXTREAMLY tail heavy) I re-inforced it with adequate strong wood, and glassed inside the wheel well area. Seems to be holding up quite well now. I had to modify the retract area a pretty good amount to get the robarts to fit in right and retract. But all in all, the plane flys great! by the way..what kind of filler putty are you all using to fill in glass "weave" and things of that nature?
Dino..just put in an order for you. THanks!
