RE: multiplex easystar help
Hi,,,Just a quick update,,my easystar is up and flying,,i finally got the parts,,i got a multiplex pico 400 duo 40 amp and a couple of mini blue servo's and the leads for my charger,,connected it all up and went flying !!!
I had a few crashes and got a bit of a bulldog nose ,but have since added some polystyrene to the inside of the nose which now cushions the blow if the batterie comes loose,also i added another rudder to the to the rudder,i sort of glued it on with little brackets and i have much more control,,nearly lost it twice in a river and got it stuck at the top of a tree but managed to retrieve it,,i have a long way to go,,,,,,,a long way,,,,,,,but i love it !!!I also use a couple of rubber bands over the hatch to keep it on,,i found the clips to be a bit weak and lost the hatch twice but also got it back again,,anyway,,having loads of fun and loads of crashes but you gotta learn right?...
