RE: Funfactor wrx rally problem?!?
its also known as the idle screw, pull off your airfilter and hold the brake on, if the carby closes fully then that is your problem, you need a credit card width gap (approx) there so the carb doesnt close fully when brakes are applied. Your idle needs to be adjusted with this screw rather than the with trim on the transmitter.
