RE: Echo CS-300
I assume your going to loose the flywheel so your looking for a hub that will fit over the shaft plus screw on the threads.Or use just the center of the flywheel and screw on a short hub against the cut down flywheel hub.what thread size is it.should be 8x1.2mm.Right hand.
