RCU Forums - View Single Post - TT 61 Pro piston orientation
Old 10-16-2007 | 12:16 AM
DarZeelon's Avatar
DarZeelon
Default RE: TT 61 Pro piston orientation
I believe it was GMS (?), who used (?) a crankshaft with the crank-pin pressed into the crank-web...
Such an arrangement tends to fall apart, but it does not have the radius where the crank-pin 'sprouts', so a symmetrical rod bottom-end is used...
