RCU Forums - View Single Post - cx/cx2 brain teaser
Old 10-16-2007 | 06:50 AM
cx2cp+'s Avatar
cx2cp+
Default cx/cx2 brain teaser
what's missing from this picture of the stock cx's parts? (it is something small, and it's not the body - actually there are two things missing!)
i rebuilt the 72mhz cx back to factory stock last night (wag problem - oops theres another one for the lingo list!) - the only body/canopy i had left was a blue one with a peeled off popo sticker, so i peeled off the other side and now its just a '44', as in magnum!
flies just like out of the box (i.e., need some servo linkage adjustments to center the trims)
and another weird thing - the cx servos don't both work at forward to pick up the swash plate - no, the right one (when viewed from the front) does for fowrad and the left one does for side to side - weird, that's like 45 degrees out? must be simething to do with it being a coaxlial
edge
edit: actually make that three things missing, but one of them is just inside its housing and hidden from view, which means i forgot to dry ice the sucker
