RCU Forums - View Single Post - Do you trim the body before or after painting
Old 04-22-2003 | 06:02 AM
1stPlaceRace
Default Do you trim the body before or after painting
If you want to remove runs your only hope is if you use acrylic paint like faskolor or acryl. Use denatured alcohol for this. Overspray can be removed from the outside of the body using the same or a orange degreaser.
