RCU Forums - View Single Post - Engine replacement for TS4N
Old 03-26-2003 | 06:14 PM
dg2b
Default Engine replacement for TS4N
According to thunder tiger, the TS4N ARTR version comes with the pro 15 engine. The engine pics "seems" to be SG crank.
You should check you engine to make sure that is the right crank. There are a lot of SG crank engines out there. The flywheel/clutch/etc should be universal to SG crank engines. You might need to buy a motor mount.
