RE: FOD Screen Question
Don,
that's the other way around.
If you have an air loss, the EGT rises, closing to the limit your turbine can take.
Therefore you have to lower the max RPM in the ECU so the turbine never exceed its max EGT.
Just think you shift up the range of use of your turbine on the EGT curve.
Got it ? Sorry my english might not be perfect.
