RE: Ultra Precision UP2 Issues
Just use a Tee from one set of door nipples for both main doors and use the second one from the valve to the nose gear door cylinders. Look in my thread about the Panther and all will be seen clearly. Don't forget to use the clippard shut off switch on the nose gear strut so the nose doors don't try to close when the gear is down, (UP3 valve only).
