RCU Forums - View Single Post - Do I need less downthrust?
Old 10-17-2007 | 08:48 PM
mboland's Avatar
mboland
Default RE: Do I need less downthrust?
I have always found the easiest test for CofG is to go inverted. The amount of down needed to hold level flight indicates how nose heavy the plane is. Add a little weight to the tail until it holds the same horizontal line inverted as it does right way up.
From there it might be easier to see what effect your thrustline is having.
