RCU Forums - View Single Post - Do I need less downthrust?
Old 10-17-2007 | 09:18 PM
bobmac010's Avatar
bobmac010
Default RE: Do I need less downthrust?
Flyboy,
Please note that different trim levels are required for different speeds too.
Slower flight requires more up elevator than faster flight. This is due to the higher lift created by the main wing at higher speeds.
If you had the stick to the firewall and it flew great, then you backed off to idle and the nose dropped, that is normal...
I hope this helps.
Bob
