RCU Forums - View Single Post - Noobs Want To Know How Your Engine Works?
Old 10-17-2007 | 10:46 PM
pupmeister's Avatar
pupmeister
Default RE: Noobs Want To Know How Your Engine Works?
ORIGINAL: bobmac010
Hey, Pup...
In your post you state There is just one small problem with your calculation, a 4 stroke completes takes only two cycles, not four to complete the process
OK, there is a reason why 4-cycle, and 4 stroke are interchangeable.
Suck - Squeeze - Bang - Blow
One, two, three, four.
Two stroke, or two cycle, up - down. Done.
Where do you think that 4 = 2 ???
I would fire your math instructor.
He said 4-stroke, not 4-revolutions.
Bob
ORIGINAL: piper_chuck
Without knowing the rpm the engine was turning, there's no way to tell. So, I'll make an assumption, for the purposes of discussion, that the engine was turning 600 rpm. If you watch the video it appears the engine made 4 complete cycles. I figured this out by counting the intakes through the right valve. With this information, the following will tell you how long the video was, in real time, and assuming 600 rpm (note that I chose 600 because it makes the numbers easy).
600 revs per minute divided by 60 seconds gives 10 revs per second
4 revs divided by 10 revs per second gives .4 second.
So, assuming the engine was turning 600 rpm, the entire video was .4 second.
You can thank my 9th grade science teacher for this analysis, he's the one who taught me the method of making such calculations. It's easy once you know the method.
For starters, 4-stroke / 4 -cycle is not inter-changeable in my book.
It takes one revolution of the engine for a two stroke engine to complete its complete cycle (intake - compression - expansion - exhaust) see this webpage [link=http://www.keveney.com/twostroke.html]Animated Engines Two Stroke Cycle[/link].
For a four stroke engine it takes two revolutions to complete its cycle (not 4 revs as stated in piper_chucks calculations), if you do not believe me you can look at this webpage [link=http://www.keveney.com/otto.html]Four Stroke Engine[/link]
Maybe you should fire your maths-instructors
Cheers
Pupmeister
